what is that piece called that is ontop of my thermostat housing... its like a vacuum sensor, someone said its for the acis. but i need to replace it and i dont know what its specifically called.
suprarx7nut;1511063 said:BVSV, same part is found on nearly all late 80's-early90's toyotas. Chances are, you can find a pristine one at a local junkyard for under 5 bucks.
