This Hose Goes to What?
j3pz
still learning
MA70witBoost;1199766 said:
no its not. I had already checked out the EPC to see if it showed something but didn't help much. Altho im going to eventually need to buy some parts off your second link but nah, didn't do much.
What goes connected to the nipple on the side of the intake manifold? by where it bolts up to the block by the front side? like above the j tube? what does that connect to?
look at the link that dumbo posted. in the picture you can see the nipple connects to the isc, then the throttle body, then to the water pipe. thats nipple>isc>tb>pipe.
many people in non-freezing temperatures bypass the isc and throttle body, going from the nipple to the water pipe.
MA70witBoost
Registered Drifter
I connected the hose from the pipe to the throttle body, have the one from the throttle body going to the isc but there is only one other big hose that i see on the isc that seems to go to the vacuum tube between the coil pack and 3000 pipe. i only see two hoses on the isc (unless im partialy blind and dont know it)
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Okay you also want to study this one.
http://cygnusx1.net/Supra/Library/EPC/291410/catalog.aspx?F=2211&P=2
That's it. There are no other stock water lines under the hood. The three hoses for the intake circuit are 22210C and 22210D shown in the link above, and 16267 from my earlier post.
22210C connects to the nipple sticking out of the intake manifold flange. 16267 connects to the wraparound steel tube.
