thinking about switching to jdm 2jz ecu, any input would be great
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
GotTurbos?;1363950 said:
You can't raise the rev limit with piggyback systems. Also G-Force isn't the only option. You can get aftermarket ecu's made for the aristo (such as Blitz) that wouldn't require you to get a piggyback that eliminates MAF. I honestly don't know if there is a Gforce made for the aristo but like I said its not the only option.
i thought you were able to change the rev limit with the emanage ultimate? y can you not change it with the emanage ultimate?
JPsToyota
231
East-Central, FL
The 6800rpm rev limit really bugs me with a larger single turbo, and even more so when I think of the headwork in the cars future. It's a given that I will be getting rid of my current 2J ecu just because of the rev limit alone, if nothing else. I have no idea as of now what I will replace it with though.
The car really does drive perfectly off boost though. It really drives well. I'm sure I will miss the current "around town" nature of the car when I change it.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
which 2jz ecu did you use? aristo or usdm supra?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
JustinGotA1j;1367335 said:
Will running a 2J ecu on a 1J allow me to run the 440cc 2J injectors without a piggyback like an safc?
You could, but that doesn't mean that you should. You should always tune your setup.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
yes like he said^^ but it will run better on a tune... you can run 440s on a 1jz ecu but need to tune
tissimo
Stock is boring :(
Melbourne, FL
Itll still be rich, as its tuned for a 3.0L engine vs the 2.5 you'll be using. But you could get away with it for a while if you had to.
