think i got a leaky HG
malloynx
NC
yea, i'm going to do that. there is also another test that you can do, which involves removing the thermostat and disabling the water pump. i'll go into more details later.
Malloy: You don't need to do it in 3 passes as you're just back cracking the Studs ie: You'll hear it CRACK as you undo it this is enough.
It's like maybe 1/16th of a turn no more then pull it straight back to the desired torque setting.
Doing it this way keeps tension on the head preventing any further problems.
malloynx
NC
here is an update. i ordered a new cometic 2.0MM HG just to be safe. i did the block test and it failed ever so slightly. i think it is only leaking under heavy boost. car runs fine, 650 idle, oil is not containmented, and i'm not loosing coolant.
i'm going to do a retorque this weekend and flush the coolant and oil system. if a retorque fails i'm going with the new MHG.
i only have 5000 miles on my rebuild. i hope the block is still in good shape as i don't want to pull it again.
