ok here is the deal. i got about 6k on the rebuild and the motor is running fine. however i think i'm losing a bit of coolant at a very small rate. i had the overflow throw up once; so i burped the system and all seems to be fine. however; when i turned the car off the other day i saw small bubbles coming from the overflow bottle. this points to exhaust gases.
i had the block and head machined very smooth and i'm running ARP head studs with a cometic 1.4mm headgasket. i DID NOT retorque the studs and i don't believe i followed ARP's instructions on the strech factor.
should i attempt a retorque?? what is the proper way to do a retorque?? loosen 1 stud at a time?? please help
