I searched and could only find 1jz location. Does anyone have diagrams or pictured instructions for the 7mgte thermostat? Also any tips when replacing would be helpful. Thanks.
me too, its better to be safe than sorryGrimJack;926374 said:They are cheap, even from the dealer. I tend to replace mine about every year just because.
vas85;928311 said:Why ever year? Are they that prone to fail? is it only a MK3 thing that they can't get right after 20 years or just a general car problem for any car owner with thermostats getting shot?....
I dont think mine's ever been replaced... so It i think is due for one, i'm just curious as to why you'd replace it every year... unless that's their life span...?
:1zhelp:
flight doc89;928426 said:thermostats are cheaper than heads
Where did you get that "spec" from?flight doc89;928426 said:because 7M heads warp like 2-3 thousandths for every 10 degrees or so overheated
mkIIIman089;928874 said:Where did you get that "spec" from?
This is exactly it. I also tend to take the front end of my engine apart fairly often to check the timing belt, and that means pulling the thermostat housing off anyway... and if it's off, you might as well replace it.AF1JZ;928314 said:Preventative maintenance. It's cheap and easy to replace. Why sit there and wait for it to fail?
Methinks you should not propagate it as gospel then.flight doc89;928921 said:guy at shop :shrug: dunno if its accurate or not. mentioned that these long I6 heads are bitches to overheat
BorHor;925415 said:It is where the upper radiator hose meets the engine. It is really easy to change.
No idea... temp ranges here go from -5 to 38, and I've never had one die on me. Of course, that might have something to do with the fact that I replace it all the time, I guess.vas85;930924 said:Do thermostats in those from the USA die that easy due to excessive weather temperature differences? Coldest here in sydney is probably 15* and warmest 35* in summer, so if they are prone to fail more often due to massive temperature differences and the fact it hits negatives often in north america... then that might make sense?
Blade2001;933736 said:I would replace the housing bolts (2) atleast once... The bottom one corroded out on mine.. had to drill out the broken stud..
