I'd hazard a guess at 105-110db at 5000rpm it gets quieter higher then that:3d_frown:IJ. said:Be interesting to see a Db test on this one
(My 3" was 97Db even with the Turbo)
AGlobalThreat said:this is good hard proof that you should get a 3" exhaust for your NA
The car has repeatedly run the old figures of between 108rwkw and 113.5 rwkw(being the highest it made after the ecu install) with the old exhaust on various dynos at various intervals so its not a case of that, not to mention it pulls better towards the limiter then before pretty much anything above 6000rpm used to be pointless as torque/tractive effort went way south.CRE said:I fail to see how, people's dynos show that kind of difference between two runs in the same session even more so after a few days.
Fuzz420 said:Very interesting information. Im currently running straight 2.5 inch piping with no muffler and i believe its just as loud. I also believe my muffler was on the restrictive side, b/c after it fell off the car felt stronger. Also after i dyno'd it again i gained 7whp, and 9lb/tq.
Yes but I wasn't going from a stock muffler now was I, a standardish 7mge on the day made 100.7rwkw (had extractors and 2.5inch cat back on an auto cressida). Not to mention the largest gains in a system specifically on an NA car are in the extractors and they remained the same because well you can't get much better then what I have anyway.Nick M said:A year apart huh? A dyno can have 5 horsepower difference with no changes between pulls.
Your losses. Still waiting to see a stock exhaust, HKS sport exhaust, and a quality 3 inch like you tested on the same car, on the same day. Or at least close and corrected.
edit; So a 3" inch exhaust yields almost 2 horsepower. Wow. I am trying to remember if I have an old test of a 7MGE bolt on test, or if one was done. I will be looking it up when I can. Because you should pick up 10 across the board as big as the stock mufflers are.
Err the stock exhuast on an MA61 is 2 1/4 inch Nick saying a 2.5inch is too big is rediculous.Nick M said:Your system is costing you power. A smaller system, but bigger than stock mind you, would increase velocity, which would increase scavenging.
2.5" was already too big.
Freudian slip?7MA61 said:My previous system showed a flat torque curve from 1500rpm to 5000rpm which definately puts end too any argument that a 2.5inch exhaust is too small.
Dyno dynamics dyno have close toa 25% drivetrain loss. So whilst my figure look low they aren't actually.
Any properly built and tuned engine does not require a significant amount of back pressure.
My old setup with a 1500rpm launch liberated at 14.789 second 1/4 at 93.29 mph with a race weight of 1382kg or 3040lbs including driver. Using a drag calculator this equates to 186-193rwhp in American figures.
You read the MA61 bit ie MK2 didn't you:doublebir Thats full weight, spare tyre rear seats and full tank of fuel in, car had sound deadening removed though but had a gravel rust proofing sprayed inside afterwards anyway.Nick M said:Freudian slip?
The sport exhaust from HKS is 60mm, which is about 2.36 inches. That is probably a good choice. When an company makes a tuned exhaust for a naturally aspirtated car, they are sold for stock applications, or an assumed 100% V.E. 180 CID engine does not need 3 inches until beyond fuel cut.
That is some heavy gutting to hit 3000 lbs. What is missing? You read the MA61 bit ie MK2 didn't you
I mentioned it in the post you commented on the low weight and clearly the vid if you watched it which I doubt is of a MK2:icon_conf .Nick M said:No. I assumed all discossion on here was for the MA70. I don't pay attention to the screen names.
