ok, ok STOP. 1st off you said you want this in a MKII. I assure you 500hp isn't
even remotely needed in a MKII. I have driven a 425rwhp MKII, and let me explain how
this car drives:
1st and 2nd gear are completely useless without drag radials:
1st gear you have to ease gently off the clutch with 1/4 throttle, then push to
1/2 throttle, then immediately shift to 2nd.
2nd gear you can push to full throttle, but by the time you hit the pedal to the floor
you need to shift to third.
oh did I mention the tires are spinning wildly?
Ok, now you're in third, whew, now you can concentrate on getting the car to go
forward, ease into the throttle and gently push to WOT, when you hit 5000, you'll
need to get ready to shift, yup redline is there.
4th, ahh finally. ok, you're in 4th you have traction, and then at 80mph the boost
guage hits 18psi, and the tires light up again, ease off ever so gently and hold on,
steer. 425rwhp+ in a street MKII is completely pointless. Chris's MKII after that we
decided on about 350rwhp. After driving a 350rwhp MKII, its MUCH more fun to
drive, you can drive it in traffic, and it doesn't have any lag to speak of and its a
whole lot FASTER AND QUICKER than a car with more HP than the tires and suspension
can handle. I have about 350rwhp in my MKII now, as 425 was just too much.
BUT that being said if you want 500rwhp, and in a MKII, this is what you need
to do:
Quality engine rebuild with forged pistons, metal head gasket, lexus, 550s, walbro,
fuel computer, fuel pressure regulator, etc. Then get a bolt on t3/t4 hybrid turbo
(you can go true T4, but its not really needed), then start working on getting your
new transmission in, and the new custom rear-end.
at 350-400rwhp you'll be breaking stock transmissions and rear ends often.
oh a 60-1 trims CT-26 with a non-clipped exhaust wheel will make a solid 350+rwhp
and spool up fast as heck
. If you are close to me at all (raleigh NC) I can take you
for a drive in my MKII.
Good luck.
Jeff
1984 7M-GTE powered MKII 350rwhp
