The Mistress
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
GrimJack;1918269 said:
~$220 per door from Toyota. I'm sure that aftermarket glass would be less if you could find it.
Well, the first problem is that I need to buy a welder, and I suspect that I need to get a 220v outlet in the garage to power it.
I used a 120 for a long time does every thing you would wana do
I used to weld sc 40 pipe with great results in my wheeler useing gas in stead of flux
it all depends on the wall socket if it is a weak plug welding will suck
only down fall to a 120 is you can not weld as long as ya could with a 220
if i was you i would just buy a good120
Hell I might even sell my old 120 if you are interested in it still works good I just ponied up a for a 220 cause I weld really thick stuff here and there
the welder is a mig pack 120 from Lincoln
NashMan
Aug 5, 2005
4,940
17
Victoria BC
Well it's up to you
220 weld thick stuff like over 1/2 inc plate 5/8
120 will go to 1/2 inc
I hardly max my welder out and weld all sorts of stuff
I still have my 120 2 of them lol for not at home job's when I go places to weld stuff since it is so portable
but if you plan to start welding aulim then a 220 is a must same a spool gun then have 2 tanks going one co2 argon mix then the other bottle straight argon
a 120 will work thou but really only for tacking
Bogwon
452
Bremerton, WA
I agree with Nashman, if you plan on welding any aluminum you'll want the 220, which sounds like what you might be thinking anyway. Good luck with what ever you decide.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
New Recaros installed, bracket fabbing courtesy of Tommy at The Independant Speed Shop.
Pardon the usual terrible pictures... I really need to learn something about photography one of these days.
Passenger side:
The nice shiny new style sliders. Much better than those really annoying levers you have to turn.
Rear mount... note the bend to keep the seat at a comfortable angle.
Front mount. Note the trick bend.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Not like I'm Ansel Adams, but for pics turn off flash, grab a tripod (even the tiny gorilla ones) and do some longer exposures.
Flash makes most pics look much worse.
Sent from my Galaxy Nexus using Tapatalk 2
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Bogwon;1922492 said:
I want some new seats for my ride soon... the stockers are just so damn uncomfortable. How are the Recaros for comfy-ness?
Enraged;1922583 said:
seats look great. comfy?
Best seats I've ever tried. Aftermarket Recaros are awesome. Don't try to compare them to the OEM Supra Recaros, those aren't nearly as nice. If you come to one of the shows you're welcome to sit in 'em.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
Did some more work on the car today... replaced a bunch of old, ugly bolts in the engine bay with these guys, and put in new hood stops. Also spent some time re-aligning the popup headlight assembly and the hood latch.
Shiny bits.
SS bolts with machined aluminum washers.
New rubber hood stops from Mark at Vancouver Toyota... this is 1 of 4. Notice the trick fusebox from Tommy at Independent Speed below. :)
Dec 31, 2010
216
IL
This car keeps me up at night, fappin' away...
Ungodly attention to detail, I get tired just watching you progress! Better build a strong shelf for trophies to go :)
NashMan
Aug 5, 2005
4,940
17
Victoria BC
how did you get around not cracking the paint when ya took off the fender bolts since yours was painted on
I herd using razor blade is the best bet ? I am gonna have to pull my fender soon
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
It looks like this model is going away, so if you ever want to have matching seats, buying two is a good idea. $1400 now is far better than $700 now, plus $1800 x 2 later down the road for a current model.
