92 Hellraiser;1828555 said:I understand. I was only concerned because it seems like cracked flex sections are not uncommon on these cars.
If I'm going to drop almost $700 on a new downpipe, I don't want to find another cracked flex section down the road.
How difficult (or effective) would it be to make a brace to the shock tower from either the manifold or turbo? Would likely alleviate some of the stress, no? Assuming of course you were on solid mounts, nobody likes torque twist...IJ.;1828773 said:Never ever ever ran a Flex pipe on any of my 7M downpipes I made and never had a stripped or damaged Header/manifold/stud.
It's the bold part I'm wondering about here... by design, a DDP would have to replace the stock elbow, would it not? The stock elbow is what causes the disruption in exhaust flow by routing the wastegate air directly into the exhaust stream...Canuckrz;1828954 said:If you're going to go balls out I would highly suggest the Raptor Racing DDP, they come ceramic coated, obviously replace the stock elbow unlike the hks, and they have the flex section aswell (which is cheap to replace if it does go, I don't know what sort of dumbass shop would say replacing is illegal).
IJ.;1828843 said:Not hard but I did scrape it often![]()
Indeed, I was just comparing to his current hks which is bottlenecked at the stock elbow to the DDP.te72;1829012 said:It's the bold part I'm wondering about here... by design, a DDP would have to replace the stock elbow, would it not? The stock elbow is what causes the disruption in exhaust flow by routing the wastegate air directly into the exhaust stream...
