Some of you have probably read where I had ten quarts of oil in my oil pan. I blamed the xpress lube where I get it changed. Turns out, it wasn't their fault. Let me explain from the begining.............
I had a new engine installed in my wifes car. The guys that installed the motor had never worked on a supra with a turbo. I was working on my wifes car yesterday and noticed that the lines were crossed under the hood by the radiator. They had my transmission lines running into the oil cooler. I've been losing transmission fluid, but just thought it was the seals leaking. (I only had the car for a week, when I put the new engine in. It had a lot of flaws that we hadn't figured out yet) I replaced the seals and thought I had that problem solved. When the turbo seals blew, I had the turbo upgraded. Changed the oil and realized that I had ten quarts of oil in the motor. Now I've got to go to the xpress lube and apologize for blaming them. Mechanics shouldn't be that stupid, but I guess even I make mistakes every now and then.....................lol
Just thought I would share that story with you. Am I the only one a mechanic has screwed over? I think not. I might be the only one willing to talk about it though..................:dunno:
