Call me an idiot, but can someone confirm or correct me when I assume that the alternator ground wire is one of the three wires (the black one) that contained in the plug in the back of the alternator.....
speed dodici said:edit: I r wrong.
the alt's ground is the motor, right?
jetjock said:Sorry, guess again idiot.
jetjock said:Very Neanderthal of you as expected. Hey, you asked and seeing how we're pals I wasn't about to pass up a freebie. What's your problem? I mean your electrical problem. I'll be glad to help. That way I'll own you, the way Siegfried owns Roy. Not interested in your other problem, whatever that is...
speed dodici said:The alt plug on the 1jz should have 3 wires.
http://www.1jz.com/tech/docs/wiring/EA21989.pdf
having the motor be the ground would make the most sense since it does bolt to the motor and thats grounded right to the chassis
