I'm about to purchase ATI 2JZ Super Damper (PN 918562) and I want to make sure that it will fit the GE short block.....
suprahero;1211752 said:How much do those cost Jose? I couldn't find it on that link.
IJ.;1212095 said:Boiling water and some antiseize on the cranksnout got my ATI on getting it off is a bitch but I hesitate to loosen up the press fit in case it gets the 7M Damper wobble/wander and trashes the crank.
soapra;1212085 said:Did you buy it new or used? Did it just slide on with just a litle bit of assembly lube? If it was used then its most likely that someone had it machined. I have installed over 20 of these and everytime, they end up on the lathe.
tissimo;1212389 said:brand new from summit.
Just used a little lube and it went on fine.
