TEMS System Components.
SWD Fredester 3
675
baltimore maryland
Good thread, as usual I'm learning something new every day. If anyone
is interested, I'm pretty sure I still have the TEMS controllers some where
in a box. Also the harness hook up is still in my car, don't know what is
involved in removing it but that could be done. It would clean up the engine
bay wiring a bit.
figgie
Twin Cities, Minnesot-ah
Guyana00;1094356 said:
figgie: As for the wiring, in a previous thread about TEMS, Jeff Lange had stated that some wiring harnesses included connectors for TEMS and some were without TEMS, so I'm believing so far that if my car has no connector shown that I wouldn't be able to dig into anywhere to find one. It would be great if I could though. If you have any proof, or something solid, from Toyota or another reliable source that would back you up then I'd be more inclined to believe you. So far though, Jeff is rarely wrong when he posts information, and to me is a very reliable source. Maybe you were just mistaken.
Nope
not mistaken. As for proof. No can do! I have a main electrical harness pulled form the car but it is a complete rats nest due to my project (ie all taping that toyota used is gone).
Like I said. The option lies on you to do.
Pull the Front wheel well panel (passenger side). It is easy to follow the electrical harness as it is held in place by holders that are tied to the chassis and runs parallel to the rear windshield washer line that feeds the nozzle towards the rear. White connector, folded on itself and taped down.
Good luck.
Kckazdude
1,239
Memphis, TN
figgie;1094681 said:
Nope
figgie, some cars did not come with TEMS equipped harnesses. I have opened 2 main harness now that did not have TEMS connectors on them. Both were 87 NA cars that didnt have the sports package.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
IJ.;1094430 said:
If something has been "built" it's rebuildable ;)
That's what I was thinking too, but I keep hearing that they're not rebuildable. I always felt like that just doesn't sound right. Where does this "can't be rebuilt" school of thought come from?
Do you know of anyone who has rebuilt and revalved tems shocks? I would do it right now, especially if they could be revalved to be stiffer. In fact I've held on to my old tems shocks on the off chance that maybe someone would be able to rebuild them.
Who would be a good candidate to approach about performing a rebuild on tems?
Any Ideas at all would be appreciated and followed-up on, as well as reported back to this site.
I'll ask a bud if he heas a spare shock I can look at.
(Pulled mine when I got the car in 97 and installed Koni's so didn't really "look" at them)
I remember sitting at the Kitchen table rebuilding a Showa rear shock out of my CR450RB race bike that was covered in "Non Rebuildable" stickers thinking "they lied" ;)
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I'm in Southern California and you'd think they're would be someone out here that might be capable and willing to do this, I'm just not sure who. I'm running koni yellows also, they're pretty good (a little stiff), but I miss the tems. I always felt like a "downgraded" the car by eliminating my tems. Such a nifty option, I hate to not have it.
Talking with my bud now, stock is Gas filled so this will be why they're non rebuildable.
My car's an 86.5 and from memory had Oil Tems, either that or they were 99% cootered and had filled the bodies with Oil ;)
jetjock;1094293 said:
^ Yep. Function (relevant input device):
1) Anti-squat (TPS)
2) Anti-dive (brake lights, speed sensor)
3) Anti-roll (steering sensor)
4) High speed firm (speed sensor)
Wow, I always wondered exactly what triggers TEMS to go to the firmest setting. This explains why I'll be sitting in my driveway sometimes and it'll have 3 lights on... then I start rolling back slowly and it's back to 2. That was confuzzling...
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Forgive me as I'm a little light on knowledge with regard to the particulars of the manufacture of nitrogen charged shocks. Why does their nitrogen charge preclude them from being rebuilt?
I understand that "oil only" dampeners would be easier, but as you said "If they can be built, they can be rebuilt." I understand that nitrogen charging throws another variable into the equation, and again, forgive me for not knowing much (anything) about how nitrogen charged shocks are made, but:
a)Is there no way to recharge them? Or is it that the equipment to do so is not something that would be available outside the factory?
b)Could they be rebuilt and revalved to work without the nitrogen charge (oil only)?
Your common sense logic I quoted in the first sentence of this post makes sense to me.
It might be expensive, but if I could get them rebuilt/revalved, I would be willing to pay more than what new tems shocks would cost. It would be worth it (to me) since they could be revalved for stiffer rebound/compression and still be OEM.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Probably because you moved the gas pedal quickly, with or without the engine running. That'll put the system in anti-squat. Either that or you were seeing the tail end of the self test where the system lights all three just after the key comes on. Anti-squat (brake pedal) couldn't have been involved because it doesn't function unless the car is moving beyond a certain speed.
Fwiw stabbing the gas while watching TEMS can be used to partially test your TPS. As I said the engine doesn't have to be running.
SB: The tops are welded on so would need to be parted off in a Lathe then new threaded tops with seals made and the tops of the tubes threaded to suit.
Then you need to find someone with the gear to recharge them.
My Bud wants to play around with an external bypass/needle valve/solenoid on a set of Koni's and have TEMS control them.
His car is still some way off but I'll post when and if we do this.
(My car still has the TEMS controller/wiring in place)
I thought about using the Top Adjusters on my Koni's with the Servo Control from the MoTeC to mimic TEMS but I can't see them reacting fast enough for it to be worth doing, that and you only get 1 Servo channel in the MoTeC.
