I have a query regarding TEMS suspension. I recently got some working TEMS suspension to put in my car along with some lowering springs. So far I have only put the front shocks and actuators in because the actuators are causing some problems. They are not going to the firm (3 squares setting when installed in the car). What I have done so far:
1. Reinstalled the TEMS shocks and actuators according to the instructions in the TSRM; set actuators and shocks to firm, put tems system in diagnostic mode. Test TEMS operation. Actuators would not go to the firm setting.
2. Tested actuators directly from the battery in all settings, actuators worked OK.
3. Tested computer, seemed OK, but the online TSRM conflicts with the JDM manual. Online manual says 12 volts constant from computer in diagnostic mode, JDM manual says .015 second 10 volt pulse. Model is JDM, so went with JDM. Any thoughts on this?
4. Tested actuators again, no problems with soft and medium settings, but will not go to firm. I can hear the actuators clicking, but very weak. Both the soleniod and the motor are getting volts. The pulse is short, so volt meter is too slow to get an accurate reading.
5. Cleaned actuators with contact cleaner/lube. I haven't dissambled them yet, would like to keep them intact as I read there are little things that could fall out.
6. Tested again, still did not go to firm setting.
I've searched the forums here, but I couldn't find any posts on this. If anyone could tell me whether I've missed something or where to go from here I would be most grateful.
Thank you.
Thank you.
