Alright.. I grounded the coilpack, I ran a permanent wire from the stock location on the coil where it grounds, to a spot a lil farther away and cleaner. It helped for a lil while, It'll start up every time now.. It still eventually runs crappy.
Heres what i noticed, When i first start it, it'll run pretty good, but eventually it'll start running crappy, so i popped the hood, and put my extra cam on the gas pedal to keep it running, under the engine bay theres exhaust comming out from under the turbo heat shield, I notice it alot more when I rev it up. It also smells extremely rich, i can actually smell unburnt fuel. Could there be an exhaust leak somewhere between the turbo and the o2 sensor causing it to run this bad?
Also, a lil bit ago i took it around the block a few times, until it started runnign crappy, enough for the engine to warm up. I put my hand on the intake manifold to lean over it and it was ice cold! none of the IC pipes were this cold, it felt like it was in the freezer for a minute or two.. and the engine was at normal temp (1/4 up the temp gauge). After it cools off im gonna pull the heatshield off the turbo and give a lil look see whats down there.
