Alright, I know i've posted alot of crap about my problems, but no ones really been able to help yet.
Last week, The supra started running all crappy. It felt like it was running on 3 cylinders, had to feather the gas to keep it running, the only time it would run normal is in boost. The problem would come and go, usually not doing it until it warmed up, or until i boosted.. Than the problem became constant, it would run crappy, wouldnt clear up, and be a pain to drive anywhere.
Than it stopped starting all together.. It would crank and crank.. not fire.
So I let it sit, for about 4 days, I tried starting it yesturday, no go.
So today, i'm out working on it. Pulled the coilpack cover thing off.. I figure, what the hell.. An i try to start it.. it fires! and runs perfect.. So i let it sit, im going around checking all the various connections, everything is fine.. The coil pack isnt bolted down, but the individual coils are on tight..
So i took it around the block a few times, took it on the road, boosted it up in first.. Low an behold it started running crappy again, it wasnt as bad.. but it took a bit of feathering to keep it running out of boost. By the time i got home it cleared up and was running fine.
WTF is going on? My DSM kinda did the same thing when the coil was going out, could it be?
