Tech/Tuner help needed !!!
88YotaTurbo
658
Wolcott, Ct.
I am running an 88 supra turbo with greddy intake, Hks SSQV BOV, 3" turbo back exhaust without a cat. I have been experiencing my fuel cut at 15 psi. I'm looking for a way to lower my psi without my silencer so I no longer hit fuel cut. I know I can buy a fuel controller or do the lex/550 mod. But I'm looking for something cheaper. Please help I am soon to autocross my car and I would love to use it without my silencer. Thank you for your time.
88YotaTurbo
658
Wolcott, Ct.
I checked today because that is what I first thought and it turns out it was not shimmed. I also checked my piping and didn't notice any cracks for boost leaks.
88YotaTurbo
658
Wolcott, Ct.
I'm using an Autometer mechanical Phantom 30-30 guage. maybe it is stuck shut????? could it be anything else?? can I limit boost via bov.??
Supracentral
10
Negative - wastegate is really the only way. The WG vents exhuast. The BOV (if you could find a way to make it leak) would just vent air that your ECU had already added fuel for - you'd wind up hitting cut even earlier.
Try removing the two bolts that hold the wastegate acutator on so you can see if the wastegate flapper moves freely. If it doesn't the problem is inside the turbo. If it does, I'd start suspecting that the actuator may have a blown diaphram.
Supracentral
10
88YotaTurbo said:
Thank you very much. I'll check on that tomorrow and get back to you. If it isn't the wastegate then what else can it be?
Make sure the little hose that goes from the compressor housing to the WG actuator is intact.
Other than that, nothing I believe.
bigboost7m
67
Center Line, MI
And make sure that hose isnt pinched, as you could hit max boost levels on the stock turbo and end up overspining it.
88YotaTurbo
658
Wolcott, Ct.
ok I check the hose running from the compressor housing to the actuater it is intact and not kinked. Then I loosend the two bolts that hold the actuater in place and it feels like a hard spring is inside the actuater. I tried to pulling on it toward the front of the car and it is quit a hard spring. i had to struggle a little bit to compress it. I'm not to certain what to look for but it seems as if everything is working properly.
However I am still boosting to 15 psi and hitting fuel cut.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Does the wastegate arm on the turbine housing move freely?
Test the actuator. Take the actuator off, use an air compressor (set the regulator to 7.5 psi) and blow air into the actuator through the hose...use a tip so it will seal on the air compressor side. If the actuator doesn't move, it's bad. Here's what the TRSM says:
http://www.cygnusx1.net/supra/library/TSRM/tc/TC_08.html
jdub
Feb 10, 2006
10,730
Valley of the Sun
tubbie said:
Could just be your boost gauge is bad....... Barrow one to see if it does the same thing......
Yeah...thought that too earlier. But if he's hitting fuel cut, likely it's fairly accurate.
88YotaTurbo
658
Wolcott, Ct.
I am hitting fuel cut. I'll describe it to you. driving hard almost wot say like 95% throttle. High rpms say 5,500 boost gauge climbs to 13, 14, 15 sudden violent jerk and CEL. Read the code and it's for turbocharger pressure or something. code 34 i think???
