TE7mgte to TE71jz build
boughart22
12
il
Hello everyone! I started with this 7mgte swap but the w58 kept breaking
[/URL]
I found a good deal 1Jz and r154..
[/URL]
I started cleaning her up... polishing and painting with hi heat. the pistons were gunky which made me suspect that the vss were toasted...
For the meantime, I started mocking up the block after I made custom brackets.
Pistons appears to be OK after cleanup
Anyways, I replaced VSS with Ferrea 2jz VSS, lots of countless hours put in, made an r154 bracket, made the driveshaft work for now by adding a bracket to the center wheel bearing... refigured intercooler pipes, then had problems with huge air pocket with no water circulating, replaced water pump and thermostat. Now the end result.
[/URL]
Thank you for taking your time to look at my build thread. I hope this inspires everybody to not give up. I want to also thank my wife and kids for the support.
te72
Classifieds Moderator
6,611
7
WHYoming
I'm sure it's obvious to the starter of this thread, but I wholly approve of this build. Both as a JZ owner and a former TE72 owner (hence the screen name), I love it. :)
boughart22
12
il
akito;2060897 said:
beautiful swap! How's the weight to power ratio of the ride?
I haven't really cornered or drifted it yet. But I can tell you that it feels lighter than the 7m and less lag with the twins. Im liking the twins but might soon upgrade to single.
To Te72... Thank u. I figured u would catch up soon.
boughart22
12
il
The car is now for sale. Im looking into installing a 2jz in a z3 coupe shoebox after driving/running the 1jz. I really love it! Cant wait to see how a jz would feel in a z3 coupe.
