targa seals leaking :(
Sawbladz
1,727
Oshawa, ON, CA
Did you replace all of the seals or just some? Did you condition the rubber after install? I have found that a slight bit of lithium grease really helps with the sealing charecteristics of the targa. HTH.
EdgeSupra
506
New Jersey
Mine leaked in the exact same spot, but its wierd.
If you leave the windows up while it's dry, then it rains, no leaks.
But if it's raining and you roll the passenger window down, then back up, it leaks a drop every 15 seconds.
I was gonna try new targa seals, but I have bigger problems to worry about right now.
-Justin
