Meh. Well I was all sorts of happy over my vid, I worked hard on it and was hoping others would enjoy it, but this shit kind of deflates my cheerfulness, and now I'm just like "whatever".
Oh, and for anyone who is interested, we're running a wideband on my POS now and getting some crazy readings. Also messing around with injector duty cycle, reading it via multimeter. Theory is that my setup should be maxing out the 182cc injectors.
On the first run, idle was at a crazy 11.1 AF and the leanest it got was 12.3 under cruise. Injector duty cycle was anywhere between 10-20%.
On the run home, hours later with cooler temps, the idle was 14.6 AF, cruise 14.3 and would plummet to 10 AF under hard acceleration to redline. The hard accel was also pushing 90% duty cycle as well.
So the current theory is that 182cc injectors at 90% duty cycle is 170ish whp. Feels about right. My dyno showed 175 ft/lbs at half throttle, didn't go WOT bc I am a retard.
ECU started throwing codes for the first time (installed 6M ECU a month ago), looks like loose plug from our messing around.
