Tanyas Mk2 Build Thread
Status
Not open for further replies.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
is not that hard really teh 7ms belts are very comon wiht otehr cars so gettign diffetn sizes is easy as cake
Tanya
1,851
Naples, FL
$230.............. then add the rinkya fees, say another $200 then add shipping, probably $100............ it adds up to being unrealistic
Good morning Tanya, and good luck on the rebuild. Hopefully you will get the desire and the funds to finish it.................lol
da89soup said:
Tanya is a Supra lover and a nimpho
There is supposedly a cure for one of those conditions, but no one I know of has tried to cure either one of them...................:naughty:
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
Tanya said:
I wouldn't be using the 7M pistons, as that would make no sense :)
I will be using the 5Ms domed pistons, effectively making a 9.8:1 compression ratio (piston pins are the same as 7Ms, will fit on the 7M rods fine, 5Ms and 7Ms have the same bore)
you say you dont want to use the 7m pistons, make sense for your route, but i have a question,
my friend and i are adding a ct26 to his set up, and he was going to rebuild the motor over summer, i told him he should be able to upgrade to the 7m rod's and pistons, and also use the 7m head on his motor, and effectly run a 2.8L 24v turbo engine. he really like's the idea' and i just want to make sure i gave him accuret info, he'll also be using 440 injectors and a mhg (go me i turn people into supra enthusest' all the time :biglaugh: ) mind you this will be in a 82 mkii, i will also be doing a similar build. :evil2: :evil2: with his car twin sister :love:
Tanya
1,851
Naples, FL
Using the 7M pistons and head would work, but I don't believe you can use the 7M con rods with the 5M crankshaft without doing some damage, some machining is required to make that work... I don't have much knowledge in that area. To be honest, I don't think that type of build is worth the headache, but then again, people tell me that staying NA isn't worth it either :)
Tanya
1,851
Naples, FL
Build is finished before it got started, car is getting parted out.
Someone please lock this.
Status
