picture 1... located on passenger side of engine rear next to the transmission plate. what is it?? looks like a banjo fitting would normally go onto it.
pic 2, do you think the oil return will be fine like this?
pic 3, the engine harness running under the EGR back plate. to much heat?? no problems if there is i have enough i can run above the firewall. and also the metal coolant line.. idk if im even using anything that its attached to anymore lol, so im thinking that is coming off also. but please correct me if im wrong.
pic 4, what can i do about the retarded hose going from the valve cover to the block?? is there a way i can make that like a SS type line? like a slip over 90 degree sweep to idk a -12 or somthing lol or will i have to rip that thing outta the block and valve cover and make idk tap it or somthing.
kinda like this
kinda like this
