well after a dissapointing dyno run, 366 at 15psi, crower cams, t61.. i was confused as to why my dyno was so low. at first i thought it was my spark plug because a couple of the runs broke up real bad up top. i put new plugs in it and it fixed the breaking up part, drove like normal and pulled like normal (really good)
but on run 1 it barely broke apart and went pretty smooth all the way till redline. so if everything went well, then how come the power output is so low?
i measured my compressor and trim came out to be 43. i know it'll effect hp output, but by how much?
i thought most of the t61 were like 57 or 60 trim or is it all different?
my main concern is that i bought the turbo i wanted.
