Working on my T4 set up & ran into a problem. I have the Drewgo Manni & the lowest part of the runners are in front of the stock turbo drain of the block. I intended to use the block flange made by ARZ but...not working out. Can I run the drain into the oil pan where the stock oil cooler line was? Now I'm also installing thermostat controlled Oil filter relocation & cooler. This eliminates the stock set up. The current oil pan line is smaller then -10 I want to use. Can I get by with I think is a -8 to -10 fitting & be ok on the drain?
I Plan to use the existing hole for stock #2 oil cooler hose shown here
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=LU&P=15
