T4 Exhaust Manifold with External wastegate
robhojy
swazzy,land
howdy all
iv looked about for some time but have been unsure where to get a exhaust manifold for my precision T67 dbb, its a T4 .68 exhaust, .75 comp
i already had an XS power manifold but the turbos comp housing fails
not sure what to do about it,
what manifolds are you guys using for the larger turbo
thanks
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Ebay manifolds are the most used ones around here and are sustaining +500HP on many builds, just inspect the manifold for burs and such, it wouldn't hurt to get it ceramic coated either. I've also heard that there is a fitment issue with the wastegate part of the manifold and it needs to be either bent, or cut and re-welded in a different location, but I'm not entirely sure as I don't own one.
robhojy
swazzy,land
yeh im looking to get around 650hp at the flywheel, was thinking maybe a cast manifold would be best
stainless cracks right?
what are peeps using on their builds
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
If you get an ebay mani it would probably be a good idea to reinforce it and do some deburring where you can. If its reinforced it shouldnt crack.
alloyguitar
it's legal, i swear...
knoxville, tennessee
I have an ebay manifold and the only issues I've had with the wastegate are that, if you plan on running a dump tube, it gets a bit tight down there.
...I don't run a dump tube, since it's down near the frame rail anyway, but it's really up to you.
I'm guessing that your compressor housing hits one of the runners...is that what we're worried about? If so, mk3brent made a riser to sit his turbo up higher, and away from the runners. I, personally, just used two spacers to raise it up about an inch. Worked like a charm.
Hope that helps,
-Devon Goodspeed
HommerSimpson
1,067
New Smyrna Beach Florida
Im installing that header RIGHT NOW 4/7/08 9:30 pm ... so far ive had to take hammer to it and grind some on oil filter housing as im runing the stock housing...
Personaly i think it sucks and would not buy another.. but was 130 shiped what ya gona do...Ill throw some pics up in a bit ...
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
hmm i was lookin at that one aswell glad i didnt buy just yet :p let us know how she fits hommer
