destrux:
Whats your AFR readings?
You see.... I replaced my stock FPR with a quality Adjustable one last week. Adjusted the fuel-pressure to Stock settings and took a test; o2 readings
increased from 10,5's to 11,5's. Response and powergains increased significantly.
The stock FPR was probably not working so well.
Happy with that result, I went for a trackday at a HUGE track with really grippy tarmac. But I was lacking waaaaay too much power to manage most of the turns on the track.
so I just stated to my self that I should try the rest of the day with some regular Racing and Time-laps instead (oh GOD its boring to do time laps)
Throug 10 miles of Time-laps, something happen though.....And I really don't know what happen, but powerlevels started to increase... especially around 3000rpm's. Power kicked in instantly at 3000, almost like the stock twins did.
At the end of the day, I managed smoooth drifting through almost the entire track, and transitient response (on-off throttle response) has switched from kinda laggy to become VERY good.
My theory is Increasing the AFR's made me more power..... and that the new turbo needed some break-in?? As it really is
much quicker now, and I'm starting to get kind of pleased with the results.
anyone heard of a Journal bearing brake-in like that before? But it works very good now, 3'rd gear drifting is easy and boost is 12-14psi (my Manual BC cant stabilize pressure entirely)
There is a dyno a few miles away from my garage, really want to check out the results with a dyno.... will post the dyno if I get it there
