grimace65 said:that makes things a lil more clear, however i dont know which turbo to go with now? cuz i would go with the sp60-1 however i was reading on a profile on a member from 7mpower.com and the didnt like maximum that turbo would go
cjennings said:Unless I am mistaken the Greddy 88 is actualy a t-66 or something, it is not a true t-88. Lag is always overrated by those that have not run a big turbo yet. My sp71gtq came online fast as sh*t and was boosting to the moon by 4000 rpm, once the boost started to come online, late 37xx rpm it just rockets.
IHI-RHC7 said:Hey Brian, How's the td08 doing?
LMAO details Brian details!chevyeater said:I think I killed it playing with the timing. It made 6 psi at 1200 rpm while I was killing it though! :biggrinki
LMAO "Mental note: do NOT try this one at home"chevyeater said:Well, it seems that if you can keep the engine running with the timing retarded about 25-30 degrees, most of the fuel will burn in the exhaust manifold. This can power the turbine very quickly with the unfortunate side effect of 1800+ F EGTs. The turbine shaft seal on the old TD08 doesn't seem to care for that much.
CtSupra said:Anyway, stop saying sp60-1! It's sp60 or sp61. Two different turbos - the 61 being the newer version of the 60. However, there is a 60-1 and a 62-1 to4 series. Sp turbos are wayyyyyyy better.
Ckanderson said:What makes SP turbo's so much better? cause they use GT wheels? thier is nothing really special about them..they also use DBB turbo's which have been proven to fail sooner.
I'm sorry, but I will stick to my 750 dollar t04r that I had custom built for me. Although the t04r might not be the hight of technology, and it might spool a little slower then a new SP turbo... but it also costs half the amount.
