I'm still unsure what spring is in the WG.... but I'm pretty sure it's a 12psi spring.aljordan said:I dunno why you're not going WOT. You've got a wideband in the car. That's all you need if you've on the stock ECU.
MK3Brent said:I'm still unsure what spring is in the WG.... but I'm pretty sure it's a 12psi spring.
I'll try tomorrow.![]()
I went WOT throttle today with a fellow supra member here.. "Yakuzastinger"siman said:Yeah Mk3Brent.
I noticed no sound coming from the WG...thats why I asked you if you were dumping internally.
If you do not go WOT, you will never know if there are any problems with the set up...like leaks etc.
Heck, I didnt go WOT on my rebuild until 3 months later:biglaugh:
-Jonathan
eh?:umno:aljordan said:Oh.. put an exhuast on it too. Just running the DP sounds horrible.
