SySt's Build up
92nsx
2,957
Clearwater, MN
you know those cadillac's came with your engine from the factory, just buy one of them then you don't have to fuck around with to many things, ;)
te72
Classifieds Moderator
6,611
7
WHYoming
hvyman;1521801 said:
long build. looking good tho.
Yeah, anything worth doing, is worth doing right though, no matter how long it takes. ;)
---------- Post added at 02:10 AM ---------- Previous post was at 02:09 AM ----------
So did my Camaro, but it's a POS. I guess that's the difference between the Caddy and the Chevy though...
SySt
Burnsville, Minnesota
No way. Are you saying the CTS-V ehxuast manifolds I am using are off of a Cadillac? You obviously don't know me very well if you think I wouldn't have to fuck around with much if I had a CTS-V. I have a really hard time leaving well enough alone.
SySt
I was not satisfied with the Cyberdyne speedometer and the bitch it was going to be to install it the way I wanted to. So I took it apart and mounted the circuit board to a peice of Lexan and am mounting that in the OEM location. I will also now be mounting the trip button in the OEM location. Pictures below.
92nsx
2,957
Clearwater, MN
I was just giving you some shit ;)
SySt
I got some more work done on the Supra. I finally get around to making a front crossmember brace as the OEM would not clear the oil pan. I still need to get out to the hardware store and pick up some bolts to install it.
SySt
School is out for the summer so i am able to put work in to the Supra more reliably now. I installed the tach adapter from Baker Electronix. The OEM tach works perfectly with the LS1 now. I also got the OEM oil pressure gauge and OEM volt meter working. All that is left for the instrument cluster now is hooking up the speedometer and check engine light. I still don't have a fuel gauge. I might have that some time this summer though. I have to finish up some exterior lighting and double check a load of things and I should be pretty set to drive around.
SySt
I am selling this Supra now. Is anyone here interested in buying this Supra? I will post up-to-date pictures of it here. If I do not find interest for the car as a whole fairly quickly I am going to part it out.
