Hey I have had this BOV installed on my 87 Supra for about two weeks now. I ran it vented to atmosphere for a few days until I could get the recirculation figured out. It worked great and no surge was noticed. I did notice that my car wasn't loving the loss of metered air and it was showing in my AFRs. So I recirculated the BOV into my intake pipe (between turbo and AFM). But now I am getting compressor surge! Bad! This turbo is brand new and I don't want to run this thing when it is causing surge. I disconnected the recirculation train from my intake pipe and ran the BOV vented to atmosphere with with recirculation train still attached, the surge is still present. So I took the recirc. fitting (recirculation and hoses/couplers) off and the surge is gone again, but my AFRs are all over the place, depending on throttle and vacuum levels.
I am assuming it is something to do with my recirculation setup. Because of the large 1.25" fitting I got a 1.25" inch to 7/8" inch coupler and took that to a 90 degree elbow (probably not ideal) to a 3/4" hose to my fitting on my intake pipe (all of the fittings I have on the intake pipe are 3/4" fittings).
My question is this: What can I do to eliminate the surge with this setup? I don't see how I can connect a line much bigger than 3/4" and I am starting with 1.25"! There is about 3 inches of space to the intake pipe from the outlet of the BOV. Does Synapse offer anything that can help? I know they make a 1" fitting, but I hate to order it if it is going to only reduce the surge, I need it eliminated! Has anyone else had this issue? You can't all have 1.25" bungs on your intakes... maybe?
I have toyed around with moving the BOV further down the line to give myself a longer run at the accordion hose, but I don't know if eliminating the 90 will solve it. Any advice, experience or ideas would be great!
I included some pictures for reference of the setup.
Thanks!
Thanks!
