Switching to GM TH400
Jimmysmk3
79
Oakhurst, NJ
hey guys im looking to go with the gm auto trans, im looking for something better for the track and the r154 im using no longer will stay in first gear.
ive looked into the adapter plates and all either be getting one from ATI or a member here on the forums. i already have the trans itself it has a full manual reverse valve body with trans brake. the mount i will be able to fab up myself and i also have a place to make a custom driveshaft. the only thing i havent figured out yet is where i can get a custom converter. i think ATI can make one but does anyone know where else?
thanks
suprarich
Guest
Nov 9, 2005
2,187
ohio
If you use an ati adaptor palte, you need an ati made custom converter. It will run near the 800.00 mark for the converter. They sell them, but do not have the converter listed in a book or the website. Each is custom made to your spec.
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
Kai;1002348 said:
The R154 is pretty good, you just have to know how not to be a bell end when you use it...
No its a POS. 2 down and no more to go, Im done with it.
Anyone else make a converter? I know they are expensive but DAMN....:aigo:
suprarich
Guest
Nov 9, 2005
2,187
ohio
HommerSimpson;1004666 said:
cant drill flywheel ? to fit converter ?
the factory flexplate has a raised area in each of the areas the converter mounts to it. You would be better off moving the mounts on the converter to match the toyota flexplate. The ATI kit comes with a SFI cert. solid steel flex plate. The factory flexplate is stamped steel.
Any convert made to handle a lot of hp is going to cost over 800.00 The type and strenght of converter you get from ATI for this kit is well worth the money.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
It's not a POS.
Ive seen people break diffs before they break r154s at the track. You're doing something wrong.
r154s arent purpose built drag racing trannys made for 5000rpm launches and 30" slicks..
dragracer
GearHead
Oct 31, 2005
221
Churubusco
thanks
Check with sound performance in Chicago. They did a few, running a modified gm torque convertor I believe. Tabs are usually welded on converter and drilled for mounting holes from factory. Shouldnt be difficult to fab something up. All depends on how much horsepower your running. I would run the ATI flexplate though. It would have to be a 8 inch converter maybe a 9 inch at best.
Rich
8,897
Try using the brakes to stop the car instead of reverse.
Jimmysmk3
79
Oakhurst, NJ
i agree the r154 can take some abuse but for a car that sees mainly track use you cant beat a built auto. im just curious what some of the people on here have done like slow66 for instance.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
and i hear mkiv guys locally who swear that they kill built autos on stock jz engines, not making an arguement i just think its funny i like the auto and cant wait to tryit out
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
RedEj8;1004988 said:
It's not a POS.
I broke the diff as well. The only thing Im doing wrong is still using the R-154. They arent purpose built from the factory no, but when I rebuilt it, it was built for drag racing and it still took a shit. I use a 26" ET Street, not even a real drag tire.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
lol sounds like you need to pull an IJ and install a ford 9" IRS setup but with a GM auto tranny. The r154s will always have the weak link sintered iron thrust washer.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Jimmysmk3;1007796 said:
well i didnt really want to turn this into a debate about how good the r154 is, im trying to get info on the auto swap
A really good set up will cost you a tick over the 4k mark.
JesseH
1,153
Englewood, Ohio, United States
I honestly think that that would be worth it if your breaking the 154's that much, hell i think that would be nice to even use as a DD/ strip car. the price kind of comes with the saying: cheap, reliable, and fast....pick two lol
fstlane88
Single time!!
South FL
You can do it for much cheaper than that, you don't need to buy parts that are rated to 7 second e.t. power levels.
I agree it's not cheap but you don't have to spend that much.
8,897
The THM is pretty stout. Just a nice performance rebuild will be stronger than the IPT A340E, which is what I will be dong for $3000. I agree, it doesn't need to cost that much.
