I tested the front bars I have tonight. I have the stock pre-89, tanabe and whiteline. The Tanabe bars was softer than I expected it to be. I am going to test that one again and make sure all my recorded data is correct. The whiteline bar was stiffer than I expected. I was hoping it would have a greater adjustment range and start around the stiffness of the stock bar and then get stiffer, but that wasn't the case.
I plan on testing the stock and Tanabe rear bar on Sunday. I forgot to tell Jdub that I need the bushings for the bars, so I don't have the mounting hardware for the whiteline bars so I can't test the rear bar yet. The front bar was close enough in size to use the tanabe bushings, so I was able to test that.
I'll try and get some numbers up soon. But unless the I messed something up while testing the tanabe bar, whiteline is the stiffest at all adjustments.
Tim
Tim
