Sway bar end links
z4ck
49
Houston
Two of my sway bar end links are on the way out (front driver, rear driver) and I was wondering if it is worth it to switch to metal adjustable end links or just get another set of OEM end links? I have Suspension Techniques sway bars.
Thanks!
z4ck
49
Houston
planemos;1925695 said:
I think it is worth it. I noticed a difference when I switched to stronger end links with my stock sway bars.
I read that the rear mounting tabs are weak and that is the reason Toyota switched to plastic rear links, thoughts?
Jul 30, 2011
99
A-Town WA
I made my own metal adjustable ones with half inch hiems and full length threaded rod. Overall cost was $60 minus new mounting hardware. I'm using tanabe sustec bars front n rear, an I mounted the hiems with titanium bolts n cres steel nuts. I still have to take them bsck apart and trim the hiem body down alil to fit jam nuts on, but I drove it as pictured along time ago an it was fricken stiff!
