swapping clusters
89supra884
170
chicago
well upon working on my friends headgasket, i realizd he has a 5 speed turbo cluster, and his car is auto non turbo, and i just swapped the 5 speed turbo into mine, and the current cluster is auto na. i know the reason my tach is not working is due to the swap, so if i swap his cluster over will my tach work again, or is there different wiring invloved.
thankyou
billy
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
it should work, remove the cluster, unscrew the tach and install the new one, took me 15 minutes in the dark with cars zooming by as I was parked on the side of the street..
89supra884
170
chicago
sounds good, ill try it tomorrow and ill let you know if it works.
thankyou
---------- Post added at 10:23 PM ---------- Previous post was at 10:21 PM ----------
and i wouldnt by any chance have to swap oil pressure gauges to, would i? because that is not working either
Did you use a jdm oil pressure sensor? If yes, then yes replace the gauge and sending unit(usdm) as hopefully you just blew out the gauge.
89supra884
170
chicago
i dont think i did, all i did was swapped engine and wiring harness, i didnt mess with the sending unit. it was weired because when i first started it up it went almost all the way up, now it just doesnt work, i have an 87 oil pressure gauge, will that work?
Is the engine a jdm engine?
The 87 will work but if you have a jdm sending unit it will fry the gauge son and you try to start the gauge.
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
WTF! lol wow i would be pissin my pants if i had todo this^FLorida Drives are Scary
89supra884
170
chicago
well i swapped tach and it worked, i also swapped oil pressure gauges and it went all the way up to 120 again, so what do i need to do to fix it, and no it is not a jdm engine
89supra884
170
chicago
where is the sensor located. i didnt switch sending units when i did the swap, are the turbo and na sending units different?
89supra884
170
chicago
hmmmm, thats weired, ill have to check it. like i said i just swapped the new one in and it started going all the way up again. thanks for the help
