Suspension troubleshooting
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
OK... i replaced both my outer tie rods since i heard knocking from both, but i still have some knocking but its much more blunt and its not felt on the steering wheel. Also my inner tie rods where very stiff, but the right one was semi stiff.
I'm guessing it is a ball joint, but i can't tell witch. All i could tell you it pulls to the right now so I'm guessing it's a upper or lower right ball joint or am i off?
Edit: just checked... there is still play in my steering.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
generally it will be the lower ball joint that is the culprit, as it is the most heavily loaded....Toyota acknowledged this and thus the lower is easily replaced (and relatively cheap too)
