The SAFC could very well be part of the issue...thing is, I'm not familar with it as to how the knobs control the different aspects of what it does. I do know it modifies the AFM signal to the ECU.
You might want to contact the previous owner and determine what you have for injectors. If you have a wideband O2, pay attention to your AFRs...you should be very close to 14.7 at idle and cruise. Under boost, 11.5 is good...you don't want to go over this AFR or you risk killing the motor.
The Lex and 550 injectors go hand-in-hand...pushing those kind of HP numbers on the stock AFM/injectors is pushing it quite a bit. Keeping off the boost is a very good idea
No...I don't have an extra Lex. You might want to consider dumping the old SAFC for a Maft Pro.
