Fuel rail up next:
Fuel rail off. If you're keeping the manifold in the bay, just pull the rail from the head and push aside.
Now comes a part that I could have made easier. The intake manifold can simply be unbolted and set aside, while still in the engine bay. I took mine off and had a hell of a time getting to all the connectors and removing all the wiring mess. In hindsight, it would have nice to simply leave it in, but now I'll have a chance to carb-clean the living hell out of it and end up with a sparkling clean intake.
Now comes the fun part. We get to see fresh gold oil covered metal.
Cam covers removed. simple unbolt and if you still have the horrible bolts, switch them out with M6 flange bolts.
reverse view
Now you need to take off the pulleys. Loosen the tensioner bolt and use a screwdriver to pry it sideways. Then tighten the tensioner bolt to keep the belt loose. Now pull of the belt. If you're doing the timing belt, the lower cover will need to be removed as well.
With the belt off, you can now remove the pulleys. The TSRM asks for a special tool that you don't have. Get a 10mm socket, the more robust the better, and stick it onto the timing plates bolts that are right behind the star of the center of the pulley. Now when you turn the pulley's bolt it will catch and you can loosen it. It may take some strentgh, but you shouldn't hurt anything. Be sure to remember to grab the pins that align the pulleys.
Headbolts are coming off. Follow the TSRM and do 3 passes in the order they give. If you dont, you may warp the head worse than it already might be. You'll need a 10mm inverse hex socket thing like this one.
You can see the bolts just under the cams and the oil will form a suction which will allow you to pull the bolts out simply with the socket. NEATO!!
After 20 mins or so and 3-4 passes the bolts are out and all lined up.
Now here's another "learning point". The water housing doesn't need to be removed, but the hoses connecting it to the block or anything other than the head do. My friend and I both missed this and pulled the head about an inch off before realizing it. We undid the hoses and coolant got onto the block surface. Contamination anyone? :nono: So I'll be doing about 5 oil changes and having the oil system fully flushed by a shop just to be sure I don't hear rod knock anytime soon.
The gasket stuck to the head and the camera ran out of battery and storage so I only have pics of the block surface for now.
WHAT DO YOU GUYS THINK?
