soapra said:
CryoSlash said:well ive heard of 3 stories. 1 about sabotage, 1 of just dislike of the platform, and 1 that your 7m blew up even though it was all in check. so im guessing number 3?
SuprA70 said:
Zazzn said:so you are running a 60-1 on the 1jz 1jz and making all that power and the other dyno was a 7m at 16 psi?
I take it the 1jz was 294?
Do you know what killed the rod bearings in your 7M? Was it oiling related or a tuning issue causing the engine to detonate, thus killing the rod bearings?SuprA70 said:Rodknock was what killed my 7M. I was even on the verge of installing the Stinger to really see what my motor was capable of. Sadly, I didn't get the chance. I don't hate the platform, maybe I'll build another one someday. The opportunity presented itself where I was able to get a built block (overbored 2.6 with 9:1 compression), so I just went from there. Most of the mods I was putting on, like the standalone, made the swap easy. The ct26 manifold by Driftmotion let me keep my 60-1 and the BIC divorced downpipe also. Right now, I'm still in the process of break-in. In a few weeks, I should be ready to put some numbers down.
One thing for sure, this car is FUN again :biglaugh:
SD2JZA70 said:Do you know what killed the rod bearings in your 7M? Was it oiling related or a tuning issue causing the engine to detonate, thus killing the rod bearings?
