supra wont rev past 3000rpm
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
open or short circuit in air flow meter signal.
could be airflow meter circuit, air flow meter, or ecu. pulled this straight from the TSRM.
you said it started when you were boosting down the street and started to stumble. do you have a boost leak/intercooler coupler that is off?
was it running good at some point after you installed the lexus/550's?
Generally when you have a boost leak a 34 will be stored.
His problem is most likely the afm but possibly the wiring as well.
