Well, after looking over how other's 57 trims are running, I think that the turbo I am running is fine, however its spiking. The car is doing its job correctly protecting my engine by cutting during spikes and I think the car wants to go more than what the turbo will let it. Initially, the turbo will hit and give me a really hard pull, then cut. I turned down the duty cycle to 40% which solved that mostly, but think I have to go down to 35% (possibly 30%) on the controller to allow it to hold better.
Also, going over my build, I think I have about .005 clearance on my rings due to the forged pistons so most of my "smoke" issues that happen during extended idle and occasionally during a very hard pull are just 7M issues with a lot of vacuum pulling some oil up the walls. Normal for a forged engine setup from my research. Engine seems healthy enough, just think that this turbo is built a little "off" or is older than it was advertised which means it will spool up to its max flow and then just basically run out of breath so although my car wants to go higher the engine just cant get enough to maintain. Definitely time to redo the turbo plan. (not rebuild, but find a different/better turbo)
I want to keep my manifold/downpipe setup so I am looking for one of the older setups that will allow me to bolt-on a better/newer turbo. I think turbonetrics bought the old greddy housing design, but I think my engine isn't killing itself (which was my main concern) so I have time.
Most of my troubles will be solved once I go standalone as well, because I am finding that while the Lexus AFM/550 setup is a good streetable power addition, it lacks the ability to do anything about how the 7M was "intended" to run. Your still running with the stock ECU setup and just fooling it to accommodate the increased air load. Its not dealing with any variances. Part of me thinks that a stock CT26 would almost be sufficient for this BPU setup although if I can get back to what the 57 Trim I had from Driftmotion used to run like I would much happier. That turbo would spool quick, pull hard, no cut and hold the power better than the 60-1. My current turbo just makes me feeling like I am tripping over my own tires lol.
Still haven't seen an actual dyno sheet of a 57 trim that answers my question mind you. Back to searching for one. Trying to find one that shows the boost curve along with the AFR curve just to see how other cars running similar setups hold and if they had the "flutter" I had and where their power dropped.
Actually.. just found what I am looking for at
http://www.supraforums.com/forum/showthread.php?322998-MK3-Dyno-Sheet-Thread
Updated after viewing a lot of dyno sheets:
Went through a lot of dyno sheets and apparently, what my "perfect" picture is in my mind isn't going to happen, so I need a brain adjustment.. lol.
The curve I was hoping for and what I was seeing on the dyno wasn't matching up, but that's because I had a wrong view of what "should" happen with everything setup correctly.
My car does what its supposed to.. spools (really quick compared to what I see on others) at about 300 HP/380 TQ and then drops off. My turbo drops off quicker and more than what I see on others (so my thinking there hasn't changed) however my power band is what its supposed to be.
My AFRs seem to reflect what is supposed to happen, too, with this setup so I am safe there, and wont be able to trim it much without doing the standalone.
I believe I am on the right path (self-educating still...) just need to do a bit farther and spend a bit more.. lol.
Feeling better about my engine though.
