Supra or Subaru (03 WRX, or a 06-07 WRX)
TurboLag
26
ILLINOIS
Heres the listing
It's time for me to sell my car, It's a 1989 5 speed turbo with 75000 miles on the body and motor. Never been in a accident, never been painted, all original.
I m the Third Owner of this car and owned for 2 years. The Car has No rust at all It was my only car so i had it for daily drive and never gave me any problems on the road and never overheated.
I recently had a mild rebuilt on the car. New fully rebuild head was install along with a HKS Metal head gasket with arp studs. torqued down to 90 lbs. I have receipts of the rebuild head.
List of things done on the car with LESS THAN 100 miles on them!!
-Rebuild head with less than 100 miles
-New Front main, oil shaft and rear main seal
- New Transmission seal where the drive shaft connects.
-HKS MHG 1.2 bead
-Arp Head Studs
-3 inch down pipe, with no cats or resonator, connected to a Blitz nur Spec Exhaust
- New Water pump
- New Timing belt
- Replaced all 3 serpentine belts
- New Toyota oil pan seal
- New 2jz 1998 Engine mounts
- New Trans fluid (MT-90)
- New Clutch and Pressure plate along with a resurfaced flywheel ---------- I m sure i m forgetting more parts.
The interior is almost in Mint Condition, the Body has original factory paint and is in great condition. I recently replaced tires all around, the rear tires have less than 1000 miles on them and the front ones have less than 2000 miles on them and i have paper work and receipts. The car has TT rims on it, the pics shows the car with my friends rims. The car comes with TT rims! not the rims.
limequat
Dissident
Detroit
I have both right now. For practicality, you have to get the WRX. 4 drs, reliable, safe, AWD, etc, etc. There is just no comparison.
For those that complain about difficulty getting power out of the WRXs, keep in mind that you don't need as much. The WRX will weigh 300-400 lbs less than a supra and AWD means flawless launches every time. A stage 2 WRX may only make 280 hp, but it'll be a dead reliable hoot to drive that won't let you down.
I tried and tried to daily drive the Supra but it keept breaking. Since giving up on the idea, I've put 110k miles on 2 WRXs and retained the Supra as a hobby.
