Fantastic post and effort! I came across this thread while searching google.
I have the head off my IS as I'm swapping it over to a GTE block, and I noticed that the exhaust ports are quite different on cylinders 1,2, and 3 (cylinders 4,5,6 look like matched pair to cylinders 1,2,3). With the manifold off, and looking straight into the exhaust port of cylinders 1 all you see is one exhaust valve that has a short run right to the exit....while the other exhaust valve is around the bend and partly swipes across the other valve on it's way out. The air has to travel further and it looks like it causes some turbulence on its way out (based on pattern of build up in the port). Cylinders 2 and 5 are more centered, cylinders 3 and 6 look like a mild version of the problem in cylinders 1,4. I wasn't planning to port the head while it's off, but I'm feeling like I should try to match each cylinder better.
Sooo, I was wondering if flow data existed for cylinders 1-3 on the exhaust side of a 2JZ-GE head, or even the GTE head. It seems difficult to believe they would all flow the same. Also, I recall Larry Windermere (Endyn) stated that even the GTE head was a challenge to get all ports to flow the same.
Thanks
