Supra Experts...help me find the source
canadian
Newbie
May 16, 2006
366
Victoria BC
I recently took out the engine (7MGTE) out of my '87 supra. I forgot to bag a few bolts because I was in a rush to get it done and finish (I know, I know...bad excuse)...
I forget where these bolts came from, I am 90% sure they came from below because of the slightly rusted and dusty color.
There are a total of 6 bolts, 4 "long" and 2 shorter sized.
Here is a picture of one:
Any help? I would liketo label this asap.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
seeing that it has the bigger washer around it. it looks like one that holds the lower plastic under panels in place.....
canadian
Newbie
May 16, 2006
366
Victoria BC
buckshotglass said:
I guess the trans to motor cast brackets. The longer bolts go on the passenger side, into the motor in the USA.
I think I may agree, that is very likely.
I will get the socket size in a minute...
canadian
Newbie
May 16, 2006
366
Victoria BC
The heads on the bolts take a 12mm socket.
The long bolts are approx. 7/8" excluding the head.
The short bolts are approx. 3/4" excluding the head.
Larry_A
You don't matter
Apr 7, 2005
102
SoCAL
The pics appear to be the bolts that hold the DS center bearing carrier, which are two [2] in number. The thick washer is the give-away for them.
If the other four [4] have thinner washers, they are likely trans-eng mount fasteners.
Good luck.
SupraMario
I think it was the google
The Farm
Dido, I've seen these things a lot, I got a bet that says thats what it is.
canadian
Newbie
May 16, 2006
366
Victoria BC
That makes sense. Maybe I put them together when I was taking it apart...thinking they belong together.
Thanks, I think thats what they are...
