Supra Electrical Problems
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Volt meter or test light
Both fuzes will get power with the ignition on but if one is getting power with the fuze removed and ignition off then it's getting power from somewhere else and will narrow down our search a bit
Rev Clown
24
Rhode Island
Alright I just removed the cig fuse and it didn't seem to be doing it but ill check in the morning to see if the battery is dead or not
Rev Clown
24
Rhode Island
Nick M;1925370 said:
So the symptoms are gone from your opening post where you have a short to postive?
So far the battery is fine so I dont think it has done it with the cig fuse out and I sat in the car for about 20 min turning the key on and off and it didnt do it at all.
8,898
Then you have isolated the circuit that is feeding B+ to IGN. As mentioned, you can put it back in, and disconnect things on that circuit one at a time.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
If pulling the fuze cut power to the circuit after the fuze then that means the short to power is between the ignition switch and the fuze...... Otherwise pulling the fuze would not shut off power to all the systems
So that means it should be in the p-l wire from acc to 1j as in my picture above
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Maybe JJ will show up and save the day... Lol
But from this point on your going to need at least some basic electrical diagnostic tools.... A test light and a decent volt/ohmmeter
Once you have those you will have to trace wires(with the tewd)... unplug connectors and check for voltage one at a time until you locate your problem
3,819
20
Thousand Oaks, CA
I would start with the wear item. Pull the IGN switch connector off and check the operation of the ignition switch with an ohmmeter. Chances are the ACC terminal is on all the time.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Sounds like a good place to start...
Not meaning to confuse the op but if that were the case wouldn't pulling both the cig and the radio fuze stop the power drain?
8,898
Rev Clown;1925724 said:
Ok so I went out to the car again today and the battery is dead so it looks like the fuse didn't solve the problem,
That may or may not be related to this.
Since I took the radio out now everything stays on with the key completely off and it acts as if the cars on.
We can't fix it for you. Not for free anyway.
Rev Clown
24
Rhode Island
Ok so I unplugged the ignition switch and checked the connectors for power. 2 of the connecters had power and the rest did not so what should be my next move now that I found the 2 connecters that have power with the ignition disconnected?
limitedgt4
85
Pawtucket, ri
Seeing that i have a similar problem, im curious to see if your does the same thing mines does as well. After i turn the key to on and then off and pull the key out, the car will lose all power after about 30 secs. Does this happen to you as well?
Rev Clown
24
Rhode Island
No my car turns off right away but what happens is sometimes the ignition turns on as if I turned the key on but the key will be completely off and out of the ignition. It doesn't always happen but I have seen it happen a lot.
limitedgt4
85
Pawtucket, ri
Thats what i meant. My instruments stay on like the radio and all the dash lights and then completely turn off like 30 secs after the key is out. Also fyi my engine is disconected so when i say on im talking about the electronics on the car
Rev Clown
24
Rhode Island
Oh I was a little confused the way you said it but yes my car is doing the same thing accept it doesn't stay on always after the key turned off it will randomly turn on instead
