The radio was staying on in my supra when the key was turned completely off so I removed the radio and found that the radio was removed before and an aftermarket deck was in before. Since I took the radio out now everything stays on with the key completely off and it acts as if the cars on. Not all the dash lights turn on only the same ones that are on when the cars running and the heat turns on its like the car is running but the key is all the way off also when this happens everything is a little dimmer then when I actually turn the key on. I have to remove the negative cable when I'm not using the car to turn everything off. Any advice?
