Super Monitor Wiring
AcIdBuRn02ZTS
227
Indiana
ok... as far as the tac working... does the turbo tac work on the NA cars but the NA tac wont work on turbo cars?
I thought it went both ways but wasnt possitive...
And what is the trick to getting the friggen speedo cable lined back up??
lol
-AcId-
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
lol
-AcId-
Speedo cable has a white clip that is around it to align it and keep it straight.
The Tach's you will want someone else to chime in on those.
AcIdBuRn02ZTS
227
Indiana
Cluster is in and looks really nice... found one small crack under the super monitor but its pretty hard to notice... much better then my previous one...
Still curious... what is the white box on the back of the cluster for? Is it part of the TEMS or is it for the boost gauge?
I got my hands on some tems struts with eibach springs... so once I get the brain box and what not... I'm gonna swap everything over...
Cant wait!!
Now I just got to do some wiring on the super monitor and I'll be set... well.. that and get my motor swapped in... details details...
-AcId-
AcIdBuRn02ZTS
227
Indiana
So I assume all the factory body harnesses have the plug but it just doenst hook to anything on the other end when in an NA car?
Also... I thought ALL pre 89 cars had the SM plug... so why dont either of mine have them or is it just hiding really well?
I'm not looking forward to the hardwire
-AcId-
AcIdBuRn02ZTS
227
Indiana
Looking at the SM plug that I received with my SM... there seems to be a difference in the wires coming off of it compared to the hardwire write up...
the one that came with mine is grey... not clear like others have pictured...
do I have the right plug?
For instance... if you look at the hardwire write up...
http://www.supra.co.nz/supermonitor/supermonitor.htm
and look at the pin out for the sm plug... the left side of the plug that has 6 pins... mine has 5 wires coming off of that side where the hardwire only shows 3... I have several other wires extra and a couple missing...
Not sure whats what at the moment... any ideas?
-AcId-
Oct 11, 2005
3,816
Thousand Oaks, CA
This is what mine has (three wires connected to the 6 pin block.).
