i have an hks bov from my sr20 swap.. its already on a pipe but where should i put it on the intercooler pipes.??
sai_supra1jz;1404850 said:You should put it somewhere along the intercooler piping. If you want a loud open sound, somewhere close to the intercooler where it isn't as covered will be a good spot.
Guyana00;1404994 said:Put it right off of the TB.
Or just close to the Tb in general.
Flateric;1405268 said:Have you also considered that you no longer will be recirculating the purge and the potential issues that will bring?
Unless of course you a recirculating your HKS unit. If so, then carry on, nothing to see here, LOL.
Guyana00;1405786 said:I don't have a sound clip, but it sounded pretty nice on the RHD one I was driving around before I sold it. Function is the main purpose, the sound is a fringe benefit for some.
jza240sx;1405368 said:yea i hear problems start coming up once you release the air into the atmosphere but that problem is solved by placing it near the TB. dont qoute me there im just saying what ive heard
Evilempire1.3JZ-GTE;1406173 said:Closer to the TB allows more time for the air to respond to the opening of it because its the futhest from the turbo to help avoid surge, Also if it is higher and it malfunctions (stuck open) if its mounted lower it can possibly suck water at vacume points (hydro lock bad) also its exposed to more elements lower on the car especialy when missing lower dust covers.
As far as Recirc on a 1JZ thats BS you could drive your 200hp 1JZ-GTE with all the turbo air plumbing disconnected and it will still run fine.
However when driving a 1JZ-GTE you would expect to get at least 280hp so I would leave the plumbing connected.
So for bov either config could be used as far as recirc and it wouldnt matter so use the most efficient & one you see fit.
Boostedmkiii;1407974 said:Although it has already been stated, I want to also say that it should be placed close to the TB.
As for the old set up, you can just have plates made and welded/bolted on the two spots. Thats what I did.
