stupid exhaust idea, but oh well - give it a lookover
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
so i've got a small welder, a little extra time and an idea.
wouldn't it be fun to weld myself a straight 2.5 inch exhaust from the header/downpipe back?
i'm talking straight pipe, nothing but a flange on one end and a few hangers. it'll be cut and welded at proper angles to make turns.
i know that this is probably not a good idea, but it only has to hold up a short time. i just wanna see how it all sounds and performs with no restrictions whatsoever. forgt the catalytic converter and muffler/resonator, this will just be stainless steel.
a cop magnet, but i won't have it on the car long enough to travel any distance to attract cops.
whats anyone think?
bluedragon17
87 NA-T baby!!!
Sep 14, 2006
382
Vacaville, CA
hmmm.........i gotts CLIP just for the wheel bearing thing i think it would be complete rice j/k j/k supras will never be rice ever and since your na you might notice a loss of power instead since na's use restriction to "scavenge" exhaust gas out of the cylinders since theres nothing forcing it out thats why turbo cars can run such huge exhausts and have no performance issues. the overlap of the valves under boost actually forces the exhaust gas out instead of by vacuum like being na
Clip
Oct 16, 2005
2,738
9
Virginia
ive only heard of power losses through 3" or bigger stuff on an NA. I think that 2.5 might create enough back pressure to keep it steady if not give it a little gain. besides, how can 6 cylinders sound like rice? haha:drink1:
Sawbladz
1,727
Oshawa, ON, CA
whats anyone think?
Why stainless? If its just going to be there for a short time, mild or aluminized steel is much cheaper and easier to weld.
Clip
Oct 16, 2005
2,738
9
Virginia
thats very true. ok, so ill go with mild steel. whats an approx. price for the steel i need?
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
My setup is a: pacesetter header to y-pipe to straight pipe. As a local ricer told me "that thing sounds like a fuggin indy car":naughty: That was after i "cleaned his clock" :biglaugh: I love the sound of my car.
fuzion
20
Moreno Valley (Riverside)
im running a straight pipe, no cat, a DNX muffler, it is LOUD and RASPY
and i love it
beside when i drive on the freeway next to a wall for a while i kinda go deaf in my left ear for a bit
Clip
Oct 16, 2005
2,738
9
Virginia
ok lets look at that minus the dnx muffler. anyone else like MDC wanna chime in?
Clip
Oct 16, 2005
2,738
9
Virginia
yellow, get me a pic of the group a dp and ill make one!
rhdmk3, explain what you mean by the exhaust cutout.
Yellow 13
Lurker
Apr 4, 2006
2,308
Fairfield, California
An exhaust cutout is a Y pipe where one end goes to nothing, and theres a lever to switch between the normal exhaust and the cutout. so you have an open flowing exhaust on demand without having to switch out all the pipes.
I have a pic of the Group A exhaust at home but its not gonna be an easy feat if this is your first time welding an exhaust.
Clip
Oct 16, 2005
2,738
9
Virginia
i was thinking about a solenoid controlled door for a cutout, but ruled it out as too expensive.
and bring on the group a exhaust. yeah its my first time, but it's gotta come sometime.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Clip
Oct 16, 2005
2,738
9
Virginia
anyone know the flange size i'll need to bolt the 2.5 inch pipe up to where the cat would sit?
and Stretch, is that a side exit?
Stretch
Toronto, Ontario
Yes, side exit exhaust. It seperates into 3 pipes at the end to minimize ground clearance, as if you had that huge pipe exiting under the side of the car, then it would equal close to zero clearance :biglaugh:
