I'm going to throw something out concerning 1 piece drive shafts...the vehicle speeds you would have to reach before the DS hits critical speed RPM are ridiculous...well above the threshold of what the engine/tranny combos are capable of.
Using this calculator...I came up with:
http://www.supramania.com/images/doward/Calculator.xls
Inputs:
Aluminum 6061, 0.125" thickness
Tube length: 39 inches
Diff Ratio: 3.91
275/35x18 rear tires
Output:
Critical Speed: 12,480 rpm
1/2 Critical Speed: 6,240 rpm
Torsional Yield: 1990 ft/lbs.
The torque this DS can handle is 4 times what you would see on a 500 HP car. On my A340E, the max MPH that can be obtained at 7000 RPM is 195 MPH. That is equivalent to a DS critical speed of 10,000 RPM...20% below the calculated critical speed of this drive shaft where failure would occur. 1/2 critical speed is where you have to pay attention to harmonic vibration...this occurs on my car at 120 MPH. DS balance and internal dampening (my Shaftmaster DS used HD foam) is extremely important at this point. Harmonics can set up a stress failure of the shaft over time if it's allowed to happen...my aluminum 1 piece has ZERO vibration at 120 MPH (1/2 critical speed). I can tell little difference between this DS and the 2 piece stock DS in terms of NVH across the RPM range and the highest speeds I've sustained.
Unfortunately, Arizona is not in Germany...hitting the highway doing 120-150 for any prolonged period of time would result in a criminal speeding and/or reckless driving charge. A track car may warrant different consideration depending on the sustained speeds.
Take this for what you will...I'm going to stick with my aluminum DS
